# Activity audit log API reference
This page provides a reference for the resource types and event types you can use as query parameters to filter responses from the Get activity audit log API.
  • Resource types specify which resource categories the API should include in the activity audit log results. For example, use include_resource_types[]=flow to retrieve only activities related to recipes.
  • Event types define the events logged for these resource types, such as creating or deleting a recipe.
The resource types and event types listed in this document are specific to the activities available in your workspace for direct customers and the admin workspace for Embedded partners. You can use the following query parameters to include or exclude these types in your results:
  • include_resource_types[]
  • include_event_types[]
  • exclude_resource_types[]
  • exclude_event_types[]
# Resource types
The following table maps each resource_type used in the API to its corresponding display name in the user interface.
Resource type Display name
Account Embedded partners only. Account settings
AccountProperty Environment properties
Adapter Custom connectors
ApiAccessProfile API access profiles
ApiClient Developer API clients
ApiCustomer API clients (API platform)
ApiEndpoint API endpoints
ApiGroup API collections
ApiPolicy API access policies
ApiPrivilegeGroup Developer API client roles
AuditLogReplicationSettings Audit log streaming
CommunityAdapterPublication Community connectors
CustomOauthKey Custom OAuth profiles
CustomOauthKeyAssignment Embedded partners only. Custom OAuth profile assignments
Deployment Project deployments
ExportManifest Manifests
Flow Recipes
Folder Folders
LCAP::Models::App Direct only. Workflow apps
LCAP::Models::Page Direct only. Workflow apps pages
LookupTable Lookup tables
ManagedUserGrant Workspace collaborators and moderators
MemberInvitation Workspace invitations
OrganizationAdapterPublication Shared connectors
Package Packages
PrivilegeGroup Collaborator roles
Project Projects
ProjectBuild Project builds
ProjectProperty Project properties
SharedAccount Connections
SharingToken Sharing tokens
Tags::Models::Tag Tags
TeamProfile Workspace admin settings
Topic Event topics
User Users. This resource type includes the Workspace and Environments subtypes, which you may encounter as the resource[type] in the API response.
WorkatoDbTable Data tables
WorkatoSchema Common data models
WorkatoTemplate Message templates
dashboards_page Insights dashboards
field_map_schema Dynamic field mapping
lcap_app_user_group_role_assignment Direct only. Workflow apps user group role assignment
lcap_app_workflow_stage Direct only. Workflow apps stages
lcap_apps_portal Direct only. Workflow apps portal
lcap_user Direct only. Workflow apps users
lcap_user_group Direct only. Workflow apps user groups
test_case Test cases
# Event types
The following events are grouped by their associated resource type. Each resource type represents a category of activities tracked in the audit log.
# Account
Event type Description
branding_updated Embedded partners only. The branding of admin and customer workspaces was updated.
# AccountProperty
account_property_created An environment property was created.
account_property_deleted An environment property was deleted.
account_property_updated An environment property was updated.
# Adapter
connector_created A custom connector was created.
connector_deleted A custom connector was deleted.
connector_installed A custom connector was installed in the workspace.
connector_released A custom connector was released.
connector_shared A custom connector was shared.
connector_shared_closed_source_changed The source code sharing settings of a custom connector were modified.
connector_updated A custom connector was updated.
# ApiAccessProfile
access_profile_api_key_refreshed The API key for an access profile was refreshed.
access_profile_created An API access profile was created.
access_profile_deleted An API access profile was deleted.
access_profile_updated An API access profile was updated.
# ApiClient
developer_api_client_created A Developer API client was created.
developer_api_client_deleted A Developer API client was deleted.
developer_api_client_updated A Developer API client was updated.
token_leaked The API token for a Developer API client was leaked.
token_regenerated A token was regenerated for a Developer API client.
# ApiCustomer
api_customer_created An API client was created in the API platform.
api_customer_deleted An API client was deleted in the API platform.
api_customer_updated An API client was updated in the API platform.
# ApiEndpoint
endpoint_activated An API endpoint was activated in an API collection.
endpoint_created An API endpoint was created in an API collection.
endpoint_deactivated An API endpoint was deactivated in an API collection.
endpoint_deleted An API endpoint was deleted from an API collection.
endpoint_updated An API endpoint was updated in an API collection.
# ApiGroup
api_collection_created An API collection was created.
api_collection_deleted An API collection was deleted.
api_collection_updated An API collection was updated.
# ApiPolicy
api_policy_created An API policy was created.
api_policy_deleted An API policy was deleted.
api_policy_updated An API policy was updated.
# ApiPrivilegeGroup
api_privilege_group_created A Developer API client role was created.
api_privilege_group_deleted A Developer API client role was deleted.
api_privilege_group_updated A Developer API client role was updated.
# AuditLogReplicationSettings
audit_log_streaming_content_updated The audit log streaming content was updated.
audit_log_streaming_destination_updated The audit log streaming destination was updated.
audit_log_streaming_disabled Audit log streaming was disabled in Workspace admin or the Admin console (Embedded).
audit_log_streaming_enabled Audit log streaming was enabled in Workspace admin or the Admin console (Embedded).
# CommunityAdapterPublication
community_adapter_publication_approved A community connector listing was approved.
community_adapter_publication_deleted A community connector listing was deleted.
community_adapter_publication_for_review A community connector listing was submitted for review.
community_adapter_publication_updated_by_admin A community connector listing was updated by an admin.
# CustomOauthKey
custom_oauth_key_created A custom OAuth profile was created.
custom_oauth_key_deleted A custom OAuth profile was deleted.
custom_oauth_key_updated A custom OAuth profile was updated.
# CustomOauthKeyAssignment
custom_oauth_profile_assignment_created Embedded partners only. A custom OAuth profile was assigned to a customer workspace or a specific environment in the customer workspace.
custom_oauth_profile_assignment_deleted Embedded partners only. A custom OAuth profile was removed from a customer workspace or a specific environment in the customer workspace.
# Deployment
deployment_failed A deployment failed.
deployment_finished A deployment finished.
deployment_review_approved A deployment was approved.
deployment_review_comment_created A comment was added to a deployment asset.
deployment_review_created A review was created for a deployment.
deployment_review_created_comment A comment was added to a deployment review.
deployment_review_deleted A deployment review was deleted.
deployment_review_rejected A deployment was rejected.
deployment_review_reset A deployment was re-opened for review.
deployment_review_updated_comment A comment added to a deployment review was updated.
deployment_submitted_for_review A deployment was submitted for review.
# ExportManifest
manifest_created A manifest was created.
manifest_deleted A manifest was deleted.
manifest_updated A manifest was updated.
# Flow
recipe_concurrency_updated A recipe's concurrency setting was updated.
recipe_copied A recipe was copied.
recipe_created A recipe was created.
recipe_data_retention_settings_updated A recipe's data retention settings were updated.
recipe_deleted A recipe was deleted.
recipe_made_private A recipe was made private.
recipe_made_public A recipe was made public.
recipe_moved A recipe was moved to a different folder.
recipe_renamed A recipe was renamed.
recipe_started A recipe was started.
recipe_stopped A recipe was stopped.
recipe_trigger_reset A recipe's trigger was reset.
recipe_undeleted A recipe was restored.
recipe_updated A recipe was updated.
tags_added Tags were added to a recipe.
tags_removed Tags were removed from a recipe.
# Folder
folder_created A folder was created.
folder_deleted A folder was deleted.
folder_moved A folder was moved to a different project or folder.
folder_renamed A folder was renamed.
# LCAP::Models::App
lcap_app_created Direct only. A Workflow app was created.
lcap_app_deleted Direct only. A Workflow app was deleted.
lcap_app_published Direct only. A Workflow app was published.
lcap_app_renamed Direct only. A Workflow app was renamed.
lcap_app_unpublished Direct only. A Workflow app was unpublished.
lcap_app_updated Direct only. A Workflow app's configuration was updated.
# LCAP::Models::Page
lcap_page_created Direct only. A Workflow app page was created.
lcap_page_deleted Direct only. A Workflow app page was deleted.
lcap_page_moved Direct only. A Workflow app page was moved.
lcap_page_renamed Direct only. A Workflow app page was renamed.
lcap_page_updated Direct only. A Workflow app page was updated.
tags_added Direct only. Tags were added to a Workflow app page.
tags_removed Direct only. Tags were removed from a Workflow app page.
# LookupTable
lookup_table_created A lookup table was created.
lookup_table_deleted A lookup table was deleted.
lookup_table_exported A lookup table was exported as a CSV file.
lookup_table_imported A lookup table was imported as a CSV file.
lookup_table_moved A lookup table was moved to a different project.
lookup_table_renamed A lookup table was renamed.
lookup_table_truncated A lookup table was truncated.
lookup_table_updated A lookup table was updated.
# ManagedUserGrant
customer_manager_assigned Embedded partners only. A customer manager was created and assigned to customer workspace(s).
customer_manager_removed Embedded partners only. A customer manager was removed from customer workspace(s).
customer_manager_updated Embedded partners only. A customer manager assignment was updated.
team_membership_created A user joined a workspace with a specific role.
team_membership_deleted A user was removed from the workspace.
team_membership_updated A user's collaborator role was updated.
workspace_moderator_assigned A workspace moderator was assigned.
workspace_moderator_removed A workspace moderator was removed.
workspace_moderator_updated A workspace moderator was updated.
# MemberInvitation
saml_sso_team_invitation_accept A collaborator accepted the workspace invitation for a workspace with SAML SSO enforcement enabled and joined with a specific role.
team_invitation_accept A user accepted the workspace invitation and joined the workspace with a specific role.
team_invitation_created A user invited another user to join the workspace with a specific role.
team_invitation_deleted A user cancelled the invitation for a user to join the workspace.
team_invitation_reject An invited user refused to join the workspace.
team_invitation_updated A user updated another user's invitation by changing their collaborator role.
# OrganizationAdapterPublication
organization_adapter_publication_created A shared connector was deployed either from Automation HQ to all workspaces or from the Admin console to Embedded customer workspaces.
organization_adapter_publication_updated A shared connector was redeployed with a new version either from Automation HQ to all workspaces or from the Admin console to Embedded customer workspaces.
organization_adapter_publication_deleted A shared connector was removed either from all workspaces or from customer workspaces.
# Package
package_exported A package was exported.
package_imported A package was imported.
# PrivilegeGroup
role_created A collaborator role was created.
role_deleted A collaborator role was deleted.
role_permissions_changed The permissions for a collaborator role changed.
role_updated A collaborator role was updated.
# Project
project_created A project was created.
project_deleted A project was deleted.
# ProjectBuild
project_build_downloaded A project build was downloaded.
# ProjectProperty
project_property_created A project property was created.
project_property_deleted A project property was deleted.
project_property_updated A project property was updated.
# SharedAccount
connection_connected A connection was established successfully.
connection_created A connection was created.
connection_deleted A connection was deleted.
connection_disconnected A connection was disconnected.
connection_moved A connection was moved to a different folder.
connection_updated A connection was edited.
tags_added Tags were added to a connection.
tags_removed Tags were removed from a connection.
# SharingToken
sharing_token_created A sharing token was generated for a recipe.
sharing_token_deleted A sharing token was revoked for a recipe.
# Tags::Models::Tag
tag_created A tag was created.
tag_deleted A tag was deleted.
tag_updated A tag was updated.
# TeamProfile
scim_token_created A System for Cross-domain Identity Management specification (SCIM) token was created.
scim_token_refreshed A SCIM token was refreshed.
scim_token_revoked A SCIM token was revoked.
team_profile_auth_method_changed The workspace authentication method was changed.
team_profile_created The workspace authentication method was created.
team_profile_handle_changed The workspace ID was changed.
team_profile_jit_provisioning_disabled SAML SSO Just-in-Time (JIT) provisioning was disabled for the workspace.
team_profile_jit_provisioning_enabled SAML SSO Just-in-Time (JIT) provisioning was enabled for the workspace.
team_profile_name_changed The workspace name was changed.
team_profile_role_sync_disabled Roles sync through SAML SSO was disabled for the workspace.
team_profile_role_sync_enabled Roles sync through SAML SSO was enabled for the workspace.
team_profile_saml_configured SAML SSO setting was saved for the workspace using a specific SAML provider.
team_profile_saml_required_disabled SAML SSO enforcement was disabled for the workspace.
team_profile_saml_required_enabled SAML SSO enforcement was enabled for the workspace.
# Topic
topic_created An event topic was created.
topic_deleted An event topic was deleted.
topic_reset An event topic was reset.
topic_retention_updated The message history retention of the event topic was updated.
topic_schema_updated An event topic schema was updated.
topic_updated An event topic was updated.
# User
account_activated A workspace was activated.
account_activation_email_resent A workspace activation email was re-sent.
account_activation_email_sent A workspace activation email was sent.
account_email_updated An account email was updated.
admin_two_fa_disabled Two-factor authentication (2FA) was disabled for the workspace.
app_access_changed App access for the workspace or for an Embedded customer workspace was updated.
aws_iam_external_id_scope_updated Amazon Web Services (AWS) Identity and Access Management (IAM) external scope was updated.
child_user_created Embedded partners only. An Embedded customer workspace was provisioned.
child_user_deleted Embedded partners only. An Embedded customer workspace was deleted, or a specific environment within a customer workspace was deleted.
data_retention_settings_updated The workspace data retention settings were updated.
delegated_admin_password_updated The delegated admin password was updated.
email_change_initiated An email change was initiated.
emails_receiving_admin_notifications_updated The admin notification email addresses were updated.
emails_receiving_error_notifications_updated The error notification email addresses were updated.
embedding_configuration_changed Embedded partners only. The embedding configuration was changed. For example, the origin URLs or frame ancestors were changed.
environment_provisioned Environments were enabled for the workspace or a specific customer workspace.
error_notification_throttling_disabled Error notification throttling was disabled.
error_notification_throttling_enabled Error notification throttling was enabled.
external_id_updated Embedded partners only. The external ID for a customer workspace or a specific environment in the customer workspace was updated.
flows_concurrency_batch_update The recipe concurrency was updated.
kms.key_id_updated The key management system key ID was updated.
kms.key_material_updated The key management system key material was updated.
kms.policy_changed The key management system policy was changed.
kms.policy_enabled The key management system policy was enabled.
kms.policy_updated The key management system policy was updated.
manager_added A delegated admin was added to the workspace.
manager_removed A delegated admin was removed from the workspace.
max_worker_concurrency_changed The maximum number of concurrent workers that can be assigned to a recipe was changed.
password_changed The account password was changed.
password_reset_requested A password reset was requested.
password_set An account password was set.
password_was_reset An account password was reset.
plan_addons_changed The add-ons for a workspace were changed.
plan_detail_changed The plan detail was updated.
plan_limit_changed The plan limit was changed.
secret_manager_cache_cleared The secrets manager cache was cleared.
secret_manager_created An external secrets manager was added to the workspace.
secret_manager_scope_updated The external secrets manager scope was updated.
secret_manager_updated The external secrets manager for the workspace was updated.
switch_environment A user switched to a different environment.
two_factor_authentication_disabled Two-factor authentication was disabled for an account.
two_factor_authentication_enabled Two-factor authentication was enabled for an account.
two_factor_authentication_recovery_codes_downloaded The two-factor authentication recovery codes for an account were downloaded.
two_factor_authentication_recovery_codes_viewed The two-factor authentication recovery codes for an account were viewed.
user_deleted A user account was deleted.
user_login A user signed in to their account.
user_login_failed A user's sign-in attempt failed.
user_logout A user signed out of their account.
user_restored A previously deleted user account was restored.
workspace_automatically_provisioned Access to a workspace was automatically provisioned.
workspace_automatically_updated Access to a workspace was automatically updated.
# WorkatoDbTable
tags_added Tags were added to a data table.
tags_removed Tags were removed from a data table.
workato_db_table_created A data table was created.
workato_db_table_deleted A data table was deleted.
workato_db_table_download The CSV file was downloaded for a data table.
workato_db_table_file_column_download A data table file column was downloaded.
workato_db_table_record_created A record was added to a data table.
workato_db_table_record_deleted A record was removed from a data table.
workato_db_table_record_updated A record was edited in a data table.
workato_db_table_renamed A data table was renamed.
workato_db_table_schema_updated The structure of a data table was updated.
# WorkatoSchema
common_data_model_created A common data model was created.
common_data_model_deleted A common data model was deleted.
common_data_model_updated A common data model was updated.
# WorkatoTemplate
message_template_created A message template was created.
message_template_deleted A message template was deleted.
message_template_updated A message template was updated.
# dashboards_page
dashboards_page_created An Insights dashboard was created.
dashboards_page_deleted An Insights dashboard was deleted.
dashboards_page_renamed An Insights dashboard was renamed.
dashboards_page_updated An Insights dashboard was updated.
# field_map_schema
field_map_schema_updated Dynamic field mapping for a recipe was updated.
# lcap_app_user_group_role_assignment
lcap_app_user_group_role_assignment_created Direct only. A role was assigned to a Workflow app user group.
lcap_app_user_group_role_assignment_deleted Direct only. A role was removed from a Workflow app user group.
lcap_app_user_group_role_assignment_updated Direct only. A role was updated for a Workflow app user group.
# lcap_app_workflow_stage
lcap_app_workflow_stage_created Direct only. A Workflow app stage was created.
lcap_app_workflow_stage_deleted Direct only. A Workflow app stage was deleted.
lcap_app_workflow_stage_renamed Direct only. A Workflow app stage was renamed.
lcap_app_workflow_stage_updated Direct only. A Workflow app stage was updated.
# lcap_apps_portal
lcap_apps_portal_authentication_settings_updated Direct only. The authentication settings of the Workflow apps portal were updated.
lcap_apps_portal_branding_settings_updated Direct only. The branding settings of the Workflow apps portal were updated.
lcap_apps_portal_embedding_settings_updated Direct only. The embedding settings of the Workflow apps portal were updated.
lcap_apps_portal_renamed Direct only. The Workflow apps portal was renamed.
lcap_apps_portal_url_updated Direct only. The Workflow apps portal URL was updated.
# lcap_user
lcap_user_deleted Direct only. A Workflow apps portal user was deleted.
lcap_user_invited Direct only. A Workflow apps portal user was invited and added.
lcap_user_renamed Direct only. A Workflow apps portal user was renamed.
lcap_user_user_groups_changed Direct only. A Workflow apps portal user was added to or removed from a user group.
# lcap_user_group
lcap_user_group_created Direct only. A Workflow apps user group was created.
lcap_user_group_deleted Direct only. A Workflow apps user group was deleted.
lcap_user_group_renamed Direct only. A Workflow apps user group was renamed.
# test_case
test_case_copied A test case was copied.
test_case_created A test case was created.
test_case_deleted A test case was deleted.
test_case_renamed A test case was renamed.
test_case_updated A test case was updated.
